WinSCP disconnect from server regualry when using SSL/TLS
Roberts
Latvia, Riga
Hello!
I am trying to syncronize local folder c:\work with remote on FTP server.
There are ~ 2Gb of files. When I use simple FTP witout SSL/TLS all files
after some time are syncronized to ftp server. But when I am using SSL/TLS
it is giving me errors after WinSCP has cpoied some files to server.
Disconnecting is happening on different file upload stages. After
I start syncronization againt it also coppies some files to server and again disconnect.
If I repeate syncronization lot lot of times WinSCP at the end has copied all files to server.
Errors, taht is shown in log are:
[i]. 2009-07-01 11:21:11.687 Asking user:
. 2009-07-01 11:21:11.687 Error listing directory '/'. ("Could not retrieve directory listing","CWD successful. ""/"" is current directory.")
[/i]
or
. 2009-07-01 11:22:21.046 Asking user:
. 2009-07-01 11:22:21.046 Error listing directory '/'. ("Could not retrieve directory listing","Directory already exists")
Using Server: FileZilla 0.9.32 beta
Using Client: WinSCP 4.22; Windows XP PRO
Transfering using: SSL/TLS Implicit
c:\FileSync\winscp422.exe session@ftp.domainname.lv /script=c:\FileSync\script.txt /log=c:\FileSync\sync.log
##script.txt
option batch on
synchronize remote -criteria=date -delete c:\work /
synchronize remote -criteria=size -delete c:\work /
put c:\FileSync\sync.log /
Re: WinSCP disconnect from server regualry when using SSL/TLS
pill
I have the exact same problem, when scripting a file transfer on an explicit TLS FileZilla server.
I am using 4.2.2 (build 480)
It works fine over SSH on other operations I use it for (4.1.9 though), but for some reason over TLS it tries to MKDIR a dir that already exists, like it did not PWD correctly or something, thus hanging when using batch on confirm off.
When batch off confirm off, I (S)kip the directory failure and it transfers some more files, until it regularly loses connection to the server, and tries again, and loses, and tries again..
I know TLS is in early implementation, but I wouldn't mind a fix ;)
Great software by the way!
Regards,
-p
