changing home directory & sounds
TravPro
Is there any way to change the server home directory? This would be great.
Plus is there a function to play sounds once the transfer has been completed?
Great app. by the way.
Re: changing home directory & sounds
Home directory can be change obviously only on server. However you may override default remote directory on Environment tab of login dialog.
No there is not. But I may add it :-)
