Error listing directory '/root'
dmnor510
Hello:
I upgraded my SSH server to Fedora 11, and when I use WinSCP to connect to it, I get the following error ==>
Unexpected directory listing line 'drwxr-x---. 22 root root 4096 Jun 16 17:38 .'.
'.' is not a valid integer value
tmrow
Re: Error listing directory '/root'
dmnor510 wrote:
Hello:
I have the same problem.
richardsite
dmnor510 wrote:
Hello:
Just upgrade
Same error occuring in Centos 6.2
I have built a number of Centos 6.2 VM's and the "Unexpected directory listing.... not a valid integer value" error also occur in this relase
I turned on loggin and here is the result:
. 2012-07-02 10:19:46.114 Detected network event
. 2012-07-02 10:19:46.114 Enumerating network events for socket 684
. 2012-07-02 10:19:46.114 Enumerated 1 network events making 1 cumulative events for socket 684
. 2012-07-02 10:19:46.114 Handling network read event on socket 684 with error 0
. 2012-07-02 10:19:46.114 Received 1439 bytes (0)
. 2012-07-02 10:19:46.114 Received 30 bytes (0)
. 2012-07-02 10:19:46.114 Read 1 bytes (1468 pending)
. 2012-07-02 10:19:46.114 Read 11 bytes (1457 pending)
< 2012-07-02 10:19:46.114 total 89596
. 2012-07-02 10:19:46.114 Read 55 bytes (1402 pending)
< 2012-07-02 10:19:46.114 drwxr-xr-x. 22 root root 4096 May 16 10:26 .
. 2012-07-02 10:19:46.114 Read 56 bytes (1346 pending)
< 2012-07-02 10:19:46.114 dr-xr-xr-x. 22 root root 4096 Jul 2 10:38 ..
. 2012-07-02 10:19:46.114 Read 61 bytes (1285 pending)
< 2012-07-02 10:19:46.115 drwxr-xr-x. 2 root root 4096 May 16 10:05 account
. 2012-07-02 10:19:46.115 Read 59 bytes (1226 pending)
< 2012-07-02 10:19:46.115 drwxr-xr-x. 10 root root 4096 May 16 11:03 cache
. 2012-07-02 10:19:46.115 Read 59 bytes (1167 pending)
< 2012-07-02 10:19:46.115 drwxr-xr-x. 2 root root 4096 Dec 8 2011 crash
. 2012-07-02 10:19:46.115 Read 56 bytes (1111 pending)
< 2012-07-02 10:19:46.115 drwxr-xr-x. 3 root root 4096 May 16 10:05 db
. 2012-07-02 10:19:46.115 Read 59 bytes (1052 pending)
< 2012-07-02 10:19:46.115 drwxr-xr-x. 3 root root 4096 May 16 10:05 empty
. 2012-07-02 10:19:46.115 Read 59 bytes (993 pending)
< 2012-07-02 10:19:46.115 drwxr-xr-x. 2 root root 4096 Sep 23 2011 games
. 2012-07-02 10:19:46.115 Read 57 bytes (936 pending)
< 2012-07-02 10:19:46.115 drwxr-xr-x. 23 root root 4096 May 16 11:08 lib
. 2012-07-02 10:19:46.115 Read 59 bytes (877 pending)
< 2012-07-02 10:19:46.115 drwxr-xr-x. 2 root root 4096 Sep 23 2011 local
. 2012-07-02 10:19:46.115 Read 58 bytes (819 pending)
< 2012-07-02 10:19:46.115 drwxrwxr-x. 5 root lock 4096 Jul 2 03:09 lock
. 2012-07-02 10:19:46.115 Read 57 bytes (762 pending)
< 2012-07-02 10:19:46.115 drwxr-xr-x. 9 root root 4096 Jul 1 03:07 log
. 2012-07-02 10:19:46.115 Read 64 bytes (698 pending)
< 2012-07-02 10:19:46.115 drwx------. 2 root root 16384 May 16 10:00 lost+found
. 2012-07-02 10:19:46.115 Read 61 bytes (637 pending)
< 2012-07-02 10:19:46.115 drwxr-xr-x. 13 1072 1072 4096 May 16 16:27 magento
. 2012-07-02 10:19:46.115 Read 73 bytes (564 pending)
< 2012-07-02 10:19:46.116 -rw-rw-r--. 1 sidneyy sidneyy 91535360 May 16 09:36 magento-1.7.0.0.tar
. 2012-07-02 10:19:46.116 Read 72 bytes (492 pending)
< 2012-07-02 10:19:46.116 lrwxrwxrwx. 1 root root 10 May 16 10:03 mail -> spool/mail
. 2012-07-02 10:19:46.116 Read 57 bytes (435 pending)
< 2012-07-02 10:19:46.116 drwxr-xr-x. 2 root root 4096 Sep 23 2011 nis
. 2012-07-02 10:19:46.116 Read 57 bytes (378 pending)
< 2012-07-02 10:19:46.116 drwxr-xr-x. 2 root root 4096 Sep 23 2011 opt
. 2012-07-02 10:19:46.116 Read 62 bytes (316 pending)
< 2012-07-02 10:19:46.116 drwxr-xr-x. 2 root root 4096 Sep 23 2011 preserve
. 2012-07-02 10:19:46.116 Read 57 bytes (259 pending)
< 2012-07-02 10:19:46.116 drwxr-xr-x. 18 root root 4096 Jun 26 16:25 run
. 2012-07-02 10:19:46.116 Read 59 bytes (200 pending)
< 2012-07-02 10:19:46.116 drwxr-xr-x. 13 root root 4096 May 16 10:05 spool
. 2012-07-02 10:19:46.116 Read 57 bytes (143 pending)
< 2012-07-02 10:19:46.116 drwxrwxrwt. 2 root root 4096 May 30 19:54 tmp
. 2012-07-02 10:19:46.116 Read 57 bytes (86 pending)
< 2012-07-02 10:19:46.116 drwxr-xr-x. 6 root root 4096 May 16 11:03 www
. 2012-07-02 10:19:46.116 Read 56 bytes (30 pending)
< 2012-07-02 10:19:46.116 drwxr-xr-x. 2 root root 4096 Sep 23 2011 yp
. 2012-07-02 10:19:46.116 Read 30 bytes (0 pending)
< 2012-07-02 10:19:46.116 WinSCP: this is end-of-file:0
* 2012-07-02 10:19:46.120 (ECommand) Error listing directory '/var'.
* 2012-07-02 10:19:46.120 Unexpected directory listing line 'drwxr-xr-x. 22 root root 4096 May 16 10:26 .'.
* 2012-07-02 10:19:46.120 '.' is not a valid integer value
. 2012-07-02 10:19:48.664 Session upkeep
. 2012-07-02 10:19:48.664 Looking for network events
Enjoy!
Sid
Re: Same error occuring in Centos 6.2
What version of WinSCP are you using? Please make sure you are using the latest one.
samerbaer
Similar Error on Android Busybox
Hi, it seems that the ls -la command on an Android busybox is not returning the inode value, here's the error I get:
Unexpected directory listing line 'drwx------ root root 2012-06-29 11:06 .ssh'.
'root' is not a valid integer value
Since I can't switch to SFTP (not implemented) i'd be happy if you could include such a "ls -la" reply line to your parser.
I've tried to connect with WinSCP 4.3.8 and 5.0.7beta
Re: Similar Error on Android Busybox
https://winscp.net/tracker/881
I have sent you an email.
samerbaer
Re: Re: Similar Error on Android Busybox
Hi, thanks for the quick reply.
I just tried the version you've linked but unfortunately it doesn't work yet.
This is the Error Message I get now:
Unexpected directory listing line 'drwxr-xr-x root root 2012-07-10 06:14 acct'.
It seems to still have Problems but the "'root' is not a valid integer value" message isn't showing any more
I just connected with putty and did an ls -la, maybe this helps:
drwxrwxrwx root root 2012-07-02 13:58 mnt
drwxrwx--x shell shell 2012-06-26 07:01 tmp
-rwxr-xr-x root root 77352 2012-06-28 15:15 toolbox
I've seen in the preview, that the message board formating kind of modifies the ls -la output,
so I'll attach a picture of my putty session.
It's the missing size column for directory entries.
Let me try to solve this.
I'll come back to you.
samerbaer
Thanks for the effort, I'll be glad to test any new versions
ropo
Re: Any news on this topic?
Sorry, it's in queue.
Still in the queue? Android is quite popular, I think
Ramadevi
Hi...
When I'm started to using the server. I'm facing this problem in winSCP3
"Unexpected directory listing line 'drwxrwxrwx. 35 root root 4096 Apr 9 19:37 .'.'.' is not a valid integer value"
Can anyone help me plz....
Please start a new thread and attach a full log file showing the problem (using the latest version of WinSCP).
