FTP maybe bug "OOPS: priv_sock_send_cmd"
Sirisian
When trying to connect to a certain server using the FTP features I receive an error box that says:
I can connect to other servers fine, but this one server is different. I can connect to this server using FireFTP (The firefox plugin). I used the same exact information.
I think a possible reason is that the FTP implementation tries to open the / directory when it connects. The server I'm connecting to forces a directory redirection and connects me to a certain folder on that server not the / directory. Just a guess though. I've connected to my 1and1 account which does the same thing and it works fine though.
Using WinSCP 4.0.2
Re: FTP maybe bug "OOPS: priv_sock_send_cmd"
Please upgrade to the latest stable version of WinSCP and post a log file showing the problem.
