server response timeout
black_ps
if you set "server response timeout" if you set it at 99999 for example or something like and connect to ftp , then you exit winscp and enter again the "server response timeout" will be 15 again,is this a bug ? using 4.1.9 build 416 using Windows XP Home Edition Service Pack 2.
Re: server response timeout
What I do:
- start WinSCP
- go to Connection tab
- set Server response timeout to different value (note that maximum is 6000, so 9999 won't fit)
- go to Stored sessions tab
- click Set defaults
- confirm setting defaults
- exit WinSCP
- start WinSCP
- the value I've set before is there
Does this work for you?
