starting from commandline
guest
is there a posibillity to start winscp from command-line without having a stored session inside winscp ?
for example with putty: putty.exe -ssh -l root -i mykeyfile.PPK myserver
Re: starting from commandline
Only possibility currently is:
winscp3.exe username@host
You may not specify private key file on command line.
Would be good if you can use winscp with the following parameter: protocol://user:pass@host/path...
e.g. winscp3.exe "scp://smith:blabla@www.server.com/home/smith/"
