Files not listing on FTP server
TJacobs
Porstmouth,NH
Using Winscp 4.2.1 on xp
Connecting to server using SSL Explict, Implicit Mode thru connection port 10021. Data are ports are 40020-40049. Connection to server and home directory okay but files are not listing hence cannot transfer.
Using Filezilla...files are displayed fine for transfer.
Using Reflections RSecure..files are displaying fine for transfer.
Testing WinSCP for scripting functionality. Anyone have an idea?
Regards
TJacobs
Re: Files not listing on FTP server
Please post a full log file showing the problem. Log file from Filezilla for comparison can be useful as well.
