Application fault, version 419, scheduled task
ChrisFromAustralia
Firstly, thanks so much for a good product.
Hi, I get this error when i call winscp from a scheduled task (the error details are from the event log):
"Faulting application winscp419.exe, version 4.1.9.416, faulting module kernel32.dll, version 5.2.3790.4480, fault address 0x0000bef7."
My scheduled task runs as the "NT AUTHORITY\SYSTEM" user. It runs a batch file with this contents:
winscp419.exe /log="logs\%date:~10,4%%date:~7,2%%date:~4,2%_winscp.log" /script=xxx.txt
Note the /log=... above - this log file does not get generated at all, so i don't know whats crashing.
My script 'xxx.txt' looks like this (censored a bit) :
option batch on
option transfer binary
open abc:def@xyz -hostkey="ssh-rsa 1024 12:34:...."
get -delete /remotefolder/* "D:\localfolder\"
close
Interestingly, when running this batch file from my normal account, i have no issues.
Any ideas?
Re: Application fault, version 419, scheduled task
ChrisFromAustralia
Australia
Thanks for the response.
Okay i've emailed you from my work account (different email address than the one i registered here with). You can respond either way.
ChrisFromAustralia
Australia
That's fine.
Thanks so much for all your efforts!
You're a credit to the open source world, giving support like that.
Don't worry that we couldn't figure it out. I've managed to hack together a solution with Putty PSFTP so don't lose any sleep over it.
Thanks again.
M Usman
SFTP Throwing error
I am getting these two errors once in a week.
1) Reporting queued error: faulting application WinSCP.exe, version 4.1.5.410, faulting module kernel32.dll, version 5.2.3790.4062, fault address 0x0000bee7.
2) Faulting application WinSCP.exe, version 4.1.5.410, faulting module kernel32.dll, version 5.2.3790.4062, fault address 0x0000bee7.
Only workaround is to reboot the server but it comes back again after 3-4 days.
Please help
Regards
Usman
Re: SFTP Throwing error
Are you able to reproduce these with the latest version? 4.1.9 or even better with 4.2.3 beta?
No One
Any update?
The bug entry in the tracker doesn't show anything but have there been any updates to this bug? Thanks
geek_jumper
SFTP throwing error
Is this issue fixed in WinSCP's latest version? I was using WinSCP 4.1.8. It was running fine in Windows server 2003(32 bits) version. Now I am running in Windows Server 2003(64bits) OS. In this OS I am frequently receiving this type of error. After rebooting server, it is running smoothly for some days and after that I am receiving the same error. Please let me know, If this bug is fixed in latest version's of WinSCP.
Re: SFTP throwing error
I do not know. But you should upgrade anyway.
