Command failed with return code 137
This is an error between WinSCP 330 on WinXP and openssh3.7.1p2 on Solaris 8.
The WinSCP session start normally, i can see the files on the solaris box, but when i'm trying a copy from Solaris to XP , i've got the message "Command failed with return code 137".
When I'm trying to copy from XP to Solaris, I've got a timeout and then a message "external exception C0000029".
My solaris sshd works normally with sftp, scp and ssh but failed with WinSCP.
Nothing abnormal in the Solaris logs...
Can you please help me ?
Guilhem
Re: Command failed with return code 137
Well actually I did...
But the error code is not the same. 127 against 137.
And the PATH to get my ssh, scp and sftp are well declared in .bashrc and .profile.
Moreover, my SSH is a OpenSSH-3.7.1p2, not a non-free one.
Guilhem
I thought it was a typo (127 => 137). Please try WinSCP 3.3.1 beta build 189. With this version the "External exception" error should not happen. However it will not solve your problem. Can you post a log file?
Actually, the beta version is working correctly in SFTP mode.
But when i'm trying the default SCP mode, the error code 137 is now on the both directions. The execption trouble has dispeared. The weird thing is that SCP works normally in console mode under Linux or Solaris and not with WinSCP...
I don't have any logs under Solaris from this problem...
Anyway, I'm able to transfer stuff between the 2 boxes. Great ! :o)
Guilhem
