Scripting
Scripting
Is there a way to specify ftp commands in scripts?
Like how do I send a
TYPE I
command. If I can specify commands will the client be aware of those commands (better said of their effect)?
I guess what I was more interested in is this:
- if I start winscp with no /passive switch, but somewhere on the way I issue a
call PASV
command, will winscp "recognize it" and use passive mode from than on?
Also somewhat related to this... I noticed that whenever Filezilla notices that a
PORT *,*,*,*,*,*
command results in a 5** response it automatically switches to passive mode. It's kind of logical to do so too. Is there a way to reach to this kind of "result" with WinSCP?
call PASV
No.
PORT *,*,*,*,*,*
No. Though the next version will suggest you to use passive mode in error message, when the server fails to open active connection.
