[solved] Show hidden files or modify LIST command
Kraeved
Moscow, Russia
Dear Martin Prikryl,
I cannot find option either to show hidden UNIX files or modify LIST command (like I'm able to do that per record with native FARFTP plugin by adding -a switch).
Is this implemented in WinSCP plugin 1.6.1 for FAR?
If not, please do. A lot of hosting providers (you may google and find out helpdesk tickets) hide files begining with point therefore editing such files (e.g. .htaccess, .htpasswd) is a great pain without seeing them in a list.
Warm regards from Russia.
Re: [wish] Show hidden files or modify LIST command
WinSCP itself supports this fully in 4.2.x. See documentation. The plugin supports that in 1.6.1 as well, though the feature is not configurable in GUI. You can set the option in registry. Or you can use WinSCP 4.2.x to configure that, the plugin will use the settings. Note though that the option is enabled by default. Log file may reveal what goes wrong. Also note that you need to have showing of hidden files enabled in FAR to actually show the files.
Sim
I usualy do not use view of hidden files on my PC in Far but I want to view hidden files on servers thru FTP. Can you add setting for permanent view of hidden files?
OK, maybe if more people ask for this.
Amjo
also in!
yes +1 for showing of hidden files!.. im going around in circles on this forum, and still unable to view my .htaccess file on my server while logging through SSH...
point is, i can keep on overwriting it upon upload each time, but let's face it, it's really not practical, and very time consuming :S
Damon
".filename.php" - are not hidden!
Requires its own set of plug-in to display hidden files.
And the type of file .htaccess or ".filename.php" - are not hidden!
Please fix it.
Thank's.
Re: ".filename.php" - are not hidden!
Please fix it.
I'm sorry, I do not undertand. Please try again.
joshi
Re: [solved] Show hidden files or modify LIST command
Click on the "view" menu (or "options", if using the Norton Commander interface).
Click on "preferences".
In the preferences window, click on "Panels" on the left menu.
Uncheck (or check) the "Show Hidden Files" box to show or hide the files.
lhdao wrote:
What is option to display hidden file in scripting. Thank you.
The hidden files are never hidden in scripting.
lhdao
It is weird, I saw files overthere, but could not download them.
If you want our help, we need more details.
