Selectively using of internal Editor
I'm commonly using WinSCP. For editing, I've defined UltraEdit in the preferences. UE but is installed on a network drive, which tooks time until starts. That doesn't matter if I will edit a file but cumbersome if only want quickly show/view file. It should be possible to bind e.g. Ctrl-F4 or (like Norton) F3 to the menu function
Files -> Edit (alternative) -> Internal Editor
if external Editor (UE) is set as position 1 in the Editor configuration.
Nice but not neccessary: if internal Editor is set to position 1 this (new) function/binding shall open with
2nd position external application/Editor to enable selective use of external editor.
Thanks in advance
Celal Dikici
Thanks in advance
Celal Dikici
