Invalid Handle error code 7, request code 9
Oasis01
Ann Arbor
WinSCP v4.0.6, I am getting the following error message when trying to browse directories simply named "In", "Out", and "Log":
Error code 7, request code 9
Are there any recommendations to resolve this error message?
The client is using windows XP Professional SP2.
Your help is most appreciative.
Re: Invalid Handle error code 7, request code 9
