FTP Connection Problem w/ Vista
kickerb
I can connect to a ftp server just fine. However, once I try to change to a different directory on the remote side, WinSCP freezes up or disconnects? I thought this might be a port forwarding issue. I forwarded port 21. That did not help.
I am running 64-bit Windows Vista Home Premium with the the current stable version of WinSCP.
I have another Vista machine (32-bit) that has the same exact problem.
Thank you for any help.
rachel
hmmm
i can't figure out how to log in... i used root and alpine as my login, and also used my ip address as listed in my wireless router... what am i doing wrong? i can't log in to the thing so i can do what i need to!! help please! :)
Re: hmmm
Please read FAQ. If that does not help, come back.
kickerb
actually i figured it out.
It was a SPI (inspection) built into my d-link router. I turned off the inspection and everything works just fine.
thanks for the help.
