Windows locks an scp file for 6 seconds
I am using winscp.com 4.1.8.415. I am using it via a Java program to access files on a secure AIX server, and then display them in a Swing GUI on an XP desktop. I have no problem getting the files, and putting them back.
The problem is that even if the file is very small (1K) there is a ALWAYS a 6 second minimum delay AFTER the winscp.com script completes, and before Windows allows me to read the file.
I execute a command such as "winscp.com user:pswd@server /script=..." see below:
option batch on
cd /some directory
get filea filea
Does winscp have the file locked? Or does Windows?
The file appears to be immediately available on the AIX server.
option batch on
cd /some directory
get filea filea
