Rights of edited files change
mike2009
I'm using 4.1.8. to connect from WinXP to SuSe-Server (root-user).
When I open a file (text based) with internal editor and save this file back, the granted rights change to 644 (instead former 755).
i found settings to force pre-defined permission to uploaded files.
This option is un-checked.
I also tried to delete the registry-key "text" without success.
This - I call it bug - is new. Former versions didn't change permissions of files.
Any workaround ?
Mike
Re: Rights of edited files change
This article partially explain the issue.
However please post a full log file showing the problem.
mike2009
sorry, I can't post a logfile, because I go down to 4.1.5 (B410), because there is everything correct (working).
But your advised article doesn't describe the problem.
In option-dialog -> transfer you have the possibility to define permission for transferred/new files.
In 4.1.5 you leave this option unchecked, then everything works fine.
In the act. version there is no matter this option is checked or not - the "pre-defined" permission 644 is given to ALL files, no matter to whom they belong or whatever permission was before "overwriting".
So I think, this option is not correct implemented in workflow.
Also very strange: the ownership (owner/group) of the new or overwritten file changes to actual user. This option - I can not find it - belongs to no customer configuration posibility.
Even there is no difference, when I check the mask, i.e. 777, the result is also 644. Even if I delete the corresponding registry-key (also tried to save config in file not in registry) does not bring any other result.
I saw that this "bug" only appears working as root. Other users don't have this problems.
If you think a logfile will be helpful to solve this tricky problem, I can install act. version on an other machine and try it out.
Hm, there were no relevant change between 4.1.5 and 4.1.8.
It would, please do.
