Passing password to a script.
cscott952
Seattle, WA
I am trying to create a script to upload files. My problem is that the server I am connecting to does not support providing a password via username:password@example.com. I have been trying to use an initialization file /ini as shown in the docs, but it doesn't work. So I have 2 questions.
1. How should I be passing a password to a script if the password can not be passed in the connection string.
2. Can a script use a ini file, or is that just for the GUI?
Thanks,
Casey
Re: passing password to a script.
What does that mean? So how do you provide password to your server?
If you cannot explain, please post a log file.
cscott952
Seattle, WA
When I try to connect as described, the connection gets closed.
winscp> open xxxxx:xxxxxx@ftp.somesite.com
Searching for host...
Connecting to host...
Authenticating...
Using username "xxxxx".
Access denied.
Connection has been unexpectedly closed. Server sent command exit status 0.
Access denied.
Authentication failed.
winscp>
The account information is correct. I can successfully connect when I don't supply password in the open statement, and supply it when prompted.
I was trying to use an .ini for this, but that doesn't seem to work. e.g.
winscp.com /ini=file.ini
file.ini containing:
[Sessions\Server]
HostName=ftp.somesite.com
UserName=xxxxxx
PasswordPlain=xxxxxxx
The .ini doesn't seem to be read. Should that work?
Please post a full log file showing the problem and another log file showing successful connection in interactive mode.
peterr
WinSCP scripting password
I am getting the same problem as described below, i.e. when prompted for a password I can connect and download the necessary files, but when i try to pass it in the open command, i.e.
open sftp://user:password@ftp.site
it always gives back
Access Denied.
peterr
here are my logs
. 2009-12-30 13:27:17.172 --------------------------------------------------------------------------
. 2009-12-30 13:27:17.172 WinSCP Version 4.2.4 (Build 610) (OS 5.1.2600 Service Pack 3)
. 2009-12-30 13:27:17.172 Login time: Wednesday, December 30, 2009 1:27:17 PM
. 2009-12-30 13:27:17.172 Session name: sftp@sfile.site.com
. 2009-12-30 13:27:17.172 Host name: sfile.site.com (Port: 22)
. 2009-12-30 13:27:17.172 User name: sftp (Password: Yes, Key file: No)
. 2009-12-30 13:27:17.172 Tunnel: No
. 2009-12-30 13:27:17.172 Transfer Protocol: SFTP
. 2009-12-30 13:27:17.172 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2009-12-30 13:27:17.172 Proxy: none
. 2009-12-30 13:27:17.172 SSH protocol version: 2; Compression: No
. 2009-12-30 13:27:17.172 Bypass authentication: No
. 2009-12-30 13:27:17.172 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2009-12-30 13:27:17.172 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2009-12-30 13:27:17.172 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2009-12-30 13:27:17.172 SFTP Bugs: -,-
. 2009-12-30 13:27:17.172 Return code variable: Autodetect; Lookup user groups: Yes
. 2009-12-30 13:27:17.172 Shell: default, EOL: 0
. 2009-12-30 13:27:17.172 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2009-12-30 13:27:17.172 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2009-12-30 13:27:17.172 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-12-30 13:27:17.172 Cache directory changes: Yes, Permanent: Yes
. 2009-12-30 13:27:17.172 DST mode: 1
. 2009-12-30 13:27:17.172 Looking up host "sfile.site.com"
. 2009-12-30 13:27:17.172 Connecting to  port 22
. 2009-12-30 13:27:20.408 Server version: SSH-2.0-1.82 sshlib: sshlibSrSshServer 1.00
. 2009-12-30 13:27:20.408 Using SSH protocol version 2
. 2009-12-30 13:27:20.408 We claim version: SSH-2.0-WinSCP_release_4.2.4
. 2009-12-30 13:27:20.564 Doing Diffie-Hellman group exchange
. 2009-12-30 13:27:21.033 Doing Diffie-Hellman key exchange with hash SHA-1
. 2009-12-30 13:27:21.314 Host key fingerprint is:
. 2009-12-30 13:27:21.314 Initialised AES-256 CBC client->server encryption
. 2009-12-30 13:27:21.314 Initialised HMAC-SHA1 client->server MAC algorithm
. 2009-12-30 13:27:21.314 Initialised AES-256 CBC server->client encryption
. 2009-12-30 13:27:21.314 Initialised HMAC-SHA1 server->client MAC algorithm
! 2009-12-30 13:27:21.799 Using username "sftp".
. 2009-12-30 13:27:21.939 Prompt (6, SSH password, , &Password: )
. 2009-12-30 13:27:21.939 Using stored password.
. 2009-12-30 13:27:21.939 Sent password
! 2009-12-30 13:27:22.174 Access denied
. 2009-12-30 13:27:22.174 Access denied
. 2009-12-30 13:27:22.174 Prompt (6, SSH password, , &Password: )
. 2009-12-30 13:27:22.174 Disconnected: Unable to authenticate
Re: WinSCP scripting password
@peterr: Are there any special characters in your password? Such as colon, slash, etc... You need to URL-encode them. Please read FAQ. If that does not help, come back.
