How to run commands from "standard input" using a .bat file?
winmhe
Berkeley, CA
I'd like to invoke winscp from a Windows .bat file, and have it execute the remaining lines in the file. Sample .bat file:
winscp /console <some syntax to say input from stdin>
open <a connection>
get <some files>
But instead of reading the lines in the .bat file, it opens a command window and prompts for a command.
Is there a way? (as this can be done with most FTP command line clients)
Thanks in advance.
Re: How to run commands from "standard input" using a .bat file?
I do not think this is possible.
What FTP clients do support that? Because if some do, than WinSCP does as well using the same syntax. As interpreting .bat file is done by Windows.
