Getting multiple files from remote server
westcottl
I have not used WinSCP before, so this may be an easy problem to solve, but I haven't figured it out.
I am using a script to connect to a remote server via SFTP. I am able to get to the correct remote directory. I have the following options set in my script: batch on and confirm off. I want to download all files from the remote directory and am executing the following: get *.* C:\myfiles\
When I do this only one of the 17 files in the remote directory is downloaded to the local machine. I am using version 4.1.8 of WinSCP. I have tried using both a .txt file and a .bat file for the script, but both result in the same problem.
When I copy the files using the GUI interface, it works fine.
Any suggestions?
Re: Getting multiple files from remote server
westcottl wrote:
andy g. wrote:
Use get * instead of *.*
Andy
Sorry, same problem. Only got one file.
Some additional information:
option transfer binary is used
The files being transferred are bitmap files each about 180K in size. Don't know if that makes any difference.
Btw, it does not matter if you use * or *.*
westcottl
The log has been emailed to you. Thanks!
