Error 3, Permission denied, Request code:3
aloe
Hi everybody!
This is my first time here.I have a problem when I attempt to upload a file.
It shows me a error: 3,Error message from server: permission denied, Request code:3. I am the owner of the file and I use Vista.
Could anybody give me an ideia how to solve this problem?
Cheers,
Aloe
Re: Error 3, Permission denied, Request code:3
Posting a log file or at least full log file may give more information.
But generally, it is your server that prevents you an access, so you should seek an advice from your server administrator.
Aeaw10
Error Code 3, request code 3, Permission denied
I just install Ubuntu 10.4 to my pc. After I finished installed linux. I try to copy files from bin folder of my window through winspc, to bin folder in linux pc. And it show Error code 3, request code 3. What can I do to solve this problems
Re: Error Code 3, request code 3, Permission denied
snowy owl
Error Code 3 Request Code 3
Error log
. 2011-11-01 10:32:59.905 --------------------------------------------------------------------------
. 2011-11-01 10:32:59.905 WinSCP Version 4.3.4 (Build 1428) (OS 6.1.7600)
. 2011-11-01 10:32:59.905 Configuration: C:\Users\ThompsAS\WinSCP\WinSCP.ini
. 2011-11-01 10:32:59.905 Login time: Tuesday, November 01, 2011 10:32:59 AM
. 2011-11-01 10:32:59.915 Session name: COBRA & FSA (Modified stored session)
. 2011-11-01 10:32:59.915 Host name: edi.conexis.com (Port: 22)
. 2011-11-01 10:32:59.915 User name: hexcel (Password: Yes, Key file: No)
. 2011-11-01 10:32:59.915 Tunnel: No
. 2011-11-01 10:32:59.915 Transfer Protocol: SFTP (SCP)
. 2011-11-01 10:32:59.915 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2011-11-01 10:32:59.925 Proxy: none
. 2011-11-01 10:32:59.925 SSH protocol version: 2; Compression: No
. 2011-11-01 10:32:59.925 Bypass authentication: No
. 2011-11-01 10:32:59.925 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2011-11-01 10:32:59.925 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2011-11-01 10:32:59.925 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2011-11-01 10:32:59.925 SFTP Bugs: -,-
. 2011-11-01 10:32:59.935 Return code variable: Autodetect; Lookup user groups: Yes
. 2011-11-01 10:32:59.935 Shell: default
. 2011-11-01 10:32:59.935 EOL: 0, UTF: 2
. 2011-11-01 10:32:59.935 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2011-11-01 10:32:59.935 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2011-11-01 10:32:59.935 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2011-11-01 10:32:59.935 Cache directory changes: Yes, Permanent: Yes
. 2011-11-01 10:32:59.945 DST mode: 1
. 2011-11-01 10:32:59.945 --------------------------------------------------------------------------
. 2011-11-01 10:32:59.965 Looking up host "edi.conexis.com"
. 2011-11-01 10:32:59.965 Connecting to 216.136.80.160 port 22
. 2011-11-01 10:33:00.125 Server version: SSH-2.0-9.99 sshlib: 7.0.0.0
. 2011-11-01 10:33:00.125 We believe remote version has SSH-2 ignore bug
. 2011-11-01 10:33:00.135 Using SSH protocol version 2
. 2011-11-01 10:33:00.135 We claim version: SSH-2.0-WinSCP_release_4.3.4
. 2011-11-01 10:33:00.195 Doing Diffie-Hellman group exchange
. 2011-11-01 10:33:00.545 Doing Diffie-Hellman key exchange with hash SHA-1
. 2011-11-01 10:33:00.848 Host key fingerprint is:
. 2011-11-01 10:33:00.848 ssh-dss 1024 df:a1:1a:da:04:02:0f:fd:a5:b7:23:79:07:9c:6c:57
. 2011-11-01 10:33:00.848 Initialised AES-256 SDCTR client->server encryption
. 2011-11-01 10:33:00.858 Initialised HMAC-SHA1 client->server MAC algorithm
. 2011-11-01 10:33:00.858 Initialised AES-256 SDCTR server->client encryption
. 2011-11-01 10:33:00.858 Initialised HMAC-SHA1 server->client MAC algorithm
! 2011-11-01 10:33:01.178 Using username "hexcel".
. 2011-11-01 10:33:01.258 Prompt (7, SSH password, , &Password: )
. 2011-11-01 10:33:01.258 Using stored password.
. 2011-11-01 10:33:01.268 Sent password
. 2011-11-01 10:33:06.258 Access granted
. 2011-11-01 10:33:06.328 Opened channel for session
. 2011-11-01 10:33:06.778 Started a shell/command
. 2011-11-01 10:33:06.798 --------------------------------------------------------------------------
. 2011-11-01 10:33:06.798 Using SFTP protocol.
. 2011-11-01 10:33:06.808 Doing startup conversation with host.
> 2011-11-01 10:33:06.808 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2011-11-01 10:33:06.868 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2011-11-01 10:33:06.868 SFTP version 3 negotiated.
. 2011-11-01 10:33:06.878 We believe the server has signed timestamps bug
. 2011-11-01 10:33:06.878 We will use UTF-8 strings for status messages only
. 2011-11-01 10:33:06.878 Getting current directory name.
. 2011-11-01 10:33:06.878 Getting real path for '.'
> 2011-11-01 10:33:06.878 Type: SSH_FXP_REALPATH, Size: 10, Number: 5904
< 2011-11-01 10:33:06.938 Type: SSH_FXP_NAME, Size: 45, Number: 5904
. 2011-11-01 10:33:06.948 Real path is '/Home/Hexcel'
. 2011-11-01 10:33:06.948 Listing directory "/Home/Hexcel".
> 2011-11-01 10:33:06.948 Type: SSH_FXP_OPENDIR, Size: 21, Number: 6155
< 2011-11-01 10:33:07.078 Type: SSH_FXP_HANDLE, Size: 13, Number: 6155
> 2011-11-01 10:33:07.078 Type: SSH_FXP_READDIR, Size: 13, Number: 6412
< 2011-11-01 10:33:07.138 Type: SSH_FXP_STATUS, Size: 30, Number: 6412
< 2011-11-01 10:33:07.138 Status code: 1
. 2011-11-01 10:33:07.138 Listing file "/Home/Hexcel/..".
> 2011-11-01 10:33:07.138 Type: SSH_FXP_LSTAT, Size: 24, Number: 6663
< 2011-11-01 10:33:07.208 Type: SSH_FXP_ATTRS, Size: 37, Number: 6663
> 2011-11-01 10:33:07.208 Type: SSH_FXP_CLOSE, Size: 13, Number: 6916
. 2011-11-01 10:33:07.208 Startup conversation with host finished.
There's no upload and hence no error in the log file you have posted. Please try again.
