Timestamp is diplayed as 00:00,
When using the option "preserve timestamp", in WinSCP the time is DISPLAYED as 00:00. When I lookup the directory listing using the ssh-Shell, I can see, that the time is obviously SET correctly by WinSCP.
Client: Windows XP
Server: SUSE Linux, Apache
Till from Munich
PS: Thank you for this very useful software !!!
Re: Timestamp is diplayed as 00:00,
WinSCP does this with SCP protocol when directory listing (ls -la) displayes file modification with date only (no time). I can hardly do something about it. You may verify this by looking to log file.
To avoid it, try SFTP instead SCP.
I do not understand this. Under ssh-shell, the ls -la lists the directory with time. But, however, with sftp it seems to work.
Many thanks for your help.
Till
Have you checked this in WinSCP log? Please take a look.
