Vista - import settings from WinXP to Vista - not working
scanreg
On WinXP box, exported settings to WinSCP.ini
Then, copied them into the new WinSCP program directory on my new Vista machine:
\Program Files\WinSCP\WinSCP.ini
However, when I restart WinSCP on the Vista machine, those imported settings are not recognized.
I read the documentation but I'm wondering if Vista is making things more complicated
Any help most appreciated, thanks
Re: Vista - import settings from WinXP to Vista - not working
Are you sure you run WinSCP from that directory?
If you go to preferences, is INI file selected?
If not, close WinSCP, remove the INI file, start WinSCP, go to preferences, select INI file, close WinSCP. Check if the INI file was created.
If not, start WinSCP, go to preferences and see if the setting was preserved. If it was not, WinSCP do not have a permission to write to the directory. If it was, WinSCP created file elsewhere, because it is actually run from elsewhere.
scanreg
Hi
Yes, it runs from C:\Program Files\WinSCP\WinSCP.exe (according to the shortcut on the desktop)
Yes, INI is selected
I tried that, went to preferences, selected INI, closed WinSCP, then re-opened, but no INI file was created - however, the previous Session had been saved (as desired) - apparently it is saving only in the registry, even though INI is selected
Yes, the INI setting was preserved
Where else could it be running from? I don't have a clue where else to look (besides in the Program Files directory)
If INI file is selected even after WinSCP restart, then INI file must exist. The selection is not stored anywhere. It is dynamically determined on WinSCP start, based on presence of the INI file in EXE directory. So if there's no C:\Program Files\WinSCP\WinSCP.ini, then you are not starting C:\Program Files\WinSCP\WinSCP.exe.
Maybe it is some feature of Vista. It may copy the EXE to some temporary directory, where it starts it from?? I do not know. If you do not manage to resolve this, come back, I'll send you a debug version to track this down. Even if you manage to resolve this, let me know what was it.
Telepath
Hellfire
Maybe its dedicated feature to deselect boons... ;)
SCNR either... ;) ;)
Telepath
Hellfire
Still not best choice install all progs under $system_directory btw...
Try to have your system as clean as you can do.
Install "user driven" apps in other partition and/or phys/logical drives.
So you have "clean" system if critical error ocures...
Freitag wrote:
Vista does not allow non-Admin users to change files under C:/Program Files directory.
It surely does, depending on file/folder permissions admin set.
Vista security is more powerful than you may think... ;)
btw: suggest "Total Commander" from https://www.ghisler.com/ as preferred
file manager for all Win-Versions.
WinSCP of course is way better than all there inbuild "ftp's", but:
Explorer is fu***ng bullshit imho... ;)
And, at least me reporting:
Works fine with no errors at all under Win 7(final, system builder) Ultimate 64 bit.
Thx to prikryl :D
