error code: 3, Message: 1291, Server: Permission denied 11
dreifels
germany
First time I use it, not familiar with PuTTY or any of SSH.
Want to access server by root, look what folders + what files are there, with timestamps.
After login successfully, I get folder tree, click on /home (or on /backup) and get
error code: 3 Request 11
Below complete log (I replaced login name, IP, and port here)
. 2009-03-28 02:30:56.468 --------------------------------------------------------------------------
. 2009-03-28 02:30:56.468 WinSCP Version 4.1.8 (Build 415) (OS 5.1.2600 Service Pack 3)
. 2009-03-28 02:30:56.468 Login time: Samstag, 28. März 2009 02:30:56
. 2009-03-28 02:30:56.468 Session name: myLoginName@111.111.111.111
. 2009-03-28 02:30:56.468 Host name: 111.111.111.111 (Port: 2222)
. 2009-03-28 02:30:56.468 User name: myLoginName (Password: No, Key file: No)
. 2009-03-28 02:30:56.468 Tunnel: No
. 2009-03-28 02:30:56.468 Transfer Protocol: SFTP (SCP)
. 2009-03-28 02:30:56.468 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2009-03-28 02:30:56.468 Proxy: none
. 2009-03-28 02:30:56.468 SSH protocol version: 2; Compression: No
. 2009-03-28 02:30:56.468 Bypass authentication: No
. 2009-03-28 02:30:56.468 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2009-03-28 02:30:56.468 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2009-03-28 02:30:56.468 SSH Bugs: -,-,-,-,-,-,-,-
. 2009-03-28 02:30:56.468 SFTP Bugs: -,-
. 2009-03-28 02:30:56.468 Return code variable: Autodetect; Lookup user groups: Yes
. 2009-03-28 02:30:56.468 Shell: default, EOL: 0
. 2009-03-28 02:30:56.468 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2009-03-28 02:30:56.468 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2009-03-28 02:30:56.468 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2009-03-28 02:30:56.468 Cache directory changes: Yes, Permanent: Yes
. 2009-03-28 02:30:56.468 DST mode: 1
. 2009-03-28 02:30:56.484 Looking up host "111.111.111.111"
. 2009-03-28 02:30:56.484 Connecting to 111.111.111.111 port 2222
. 2009-03-28 02:30:56.843 Server version: SSH-2.0-OpenSSH_3.9p1
. 2009-03-28 02:30:56.890 We claim version: SSH-2.0-WinSCP_release_4.1.8
. 2009-03-28 02:30:56.921 SSPI: acquired credentials for: YYY@ZZZ
. 2009-03-28 02:30:56.921 Cannot convert IP address to SPN: DNS is not trusted
. 2009-03-28 02:30:56.937 GSSKEX disabled:
. 2009-03-28 02:30:56.937 Using SSH protocol version 2
. 2009-03-28 02:30:57.031 Doing Diffie-Hellman group exchange
. 2009-03-28 02:30:57.312 Doing Diffie-Hellman key exchange with hash SHA-1
. 2009-03-28 02:30:57.671 Host key fingerprint is:
. 2009-03-28 02:30:57.687 ssh-rsa 1024 f3:7a:7c:07:0a:32:4f:e6:37:6e:ae:3c:ad:33:d3:9e
. 2009-03-28 02:30:57.687 Initialised AES-256 SDCTR client->server encryption
. 2009-03-28 02:30:57.687 Initialised HMAC-SHA1 client->server MAC algorithm
. 2009-03-28 02:30:57.687 Initialised AES-256 SDCTR server->client encryption
. 2009-03-28 02:30:57.687 Initialised HMAC-SHA1 server->client MAC algorithm
! 2009-03-28 02:30:57.968 Using username "myLoginName".
. 2009-03-28 02:30:58.125 Prompt (6, SSH password, , &Passwort:)
. 2009-03-28 02:31:14.500 Sent password
. 2009-03-28 02:31:14.640 Access granted
. 2009-03-28 02:31:14.750 Opened channel for session
. 2009-03-28 02:31:14.890 Started a shell/command
. 2009-03-28 02:31:14.890 --------------------------------------------------------------------------
. 2009-03-28 02:31:14.890 Using SFTP protocol.
. 2009-03-28 02:31:14.890 Doing startup conversation with host.
> 2009-03-28 02:31:14.890 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2009-03-28 02:31:15.015 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2009-03-28 02:31:15.062 SFTP version 3 negotiated.
. 2009-03-28 02:31:15.062 We believe the server has signed timestamps bug
. 2009-03-28 02:31:15.062 We will use UTF-8 strings for status messages only
. 2009-03-28 02:31:15.062 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2009-03-28 02:31:15.062 Getting current directory name.
. 2009-03-28 02:31:15.062 Getting real path for '.'
> 2009-03-28 02:31:15.062 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2009-03-28 02:31:15.187 Type: SSH_FXP_NAME, Size: 47, Number: 16
. 2009-03-28 02:31:15.187 Real path is '/home/myLoginName'
. 2009-03-28 02:31:15.187 Listing directory "/home/myLoginName".
> 2009-03-28 02:31:15.187 Type: SSH_FXP_OPENDIR, Size: 22, Number: 267
< 2009-03-28 02:31:15.312 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
> 2009-03-28 02:31:15.421 Type: SSH_FXP_READDIR, Size: 13, Number: 524
< 2009-03-28 02:31:15.562 Type: SSH_FXP_NAME, Size: 681, Number: 524
> 2009-03-28 02:31:15.562 Type: SSH_FXP_READDIR, Size: 13, Number: 780
< 2009-03-28 02:31:15.687 Type: SSH_FXP_STATUS, Size: 28, Number: 780
< 2009-03-28 02:31:15.718 Status/error code: 1
> 2009-03-28 02:31:15.718 Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
. 2009-03-28 02:31:15.718 Startup conversation with host finished.
. 2009-03-28 02:31:26.921 Cached directory change via "/home" to "/home".
. 2009-03-28 02:31:26.921 Getting current directory name.
. 2009-03-28 02:31:26.921 Listing directory "/home".
> 2009-03-28 02:31:26.921 Type: SSH_FXP_OPENDIR, Size: 14, Number: 1291
< 2009-03-28 02:31:26.921 Type: SSH_FXP_STATUS, Size: 24, Number: 1028
. 2009-03-28 02:31:26.921 Discarding reserved response
< 2009-03-28 02:31:27.046 Type: SSH_FXP_STATUS, Size: 34, Number: 1291
< 2009-03-28 02:31:27.046 Status/error code: 3, Message: 1291, Server: Permission denied, Language:
* 2009-03-28 02:31:27.062 (ECommand) Fehler beim Anzeigen des Verzeichnisses "/home".
* 2009-03-28 02:31:27.062 Erlaubnis verweigert.
* 2009-03-28 02:31:27.062 Fehlernummer: 3
* 2009-03-28 02:31:27.062 Fehlermeldung vom entfernten Rechner : Permission denied
* 2009-03-28 02:31:27.062 Anforderungsnummer: 11
. 2009-03-28 02:31:41.890 Closing connection.
. 2009-03-28 02:31:41.890 Sending special code: 12
. 2009-03-28 02:31:41.890 Sent EOF message
Re: error code: 3, Message: 1291, Server: Permission denied 11
As you can see in the error message ("Permission denied") you do not have permissions to enter or list that directory.
Well, I'm sorry. But that's not a problem of WinSCP. Your should seek a help with administrator of your server or vendor of your SFTP server. It is the server who denies you access.
