URGENT - "put -nopreservetime" in script does not work, HELP
rmundkowsky
Hi, I am using 4.1.8. in interactive command line interface mode, the commands listed below work. But if I put them into a script file and run them then Winscp thinks -nopreservetime and –nopermissions are file names rather than an option. I am using SFTP. I would note that we are using the old INI file that can with version 3, not sure if that makes a difference.
SCRIPT:
option batch on
option batch abort
open AAAA:BBB@XYZ.com
lcd C:\temp\t
lls
cd IN
put -nopreservetime –nopermissions "test.zip"
ls
bye
PARTIAL OUTPUT FROM LOG:
. 2009-03-24 11:34:01.134 Asking user:
. 2009-03-24 11:34:01.134 File or folder '–nopermissions' does not exist. ()
* 2009-03-24 11:34:01.149 (EScpSkipFile) File or folder '–nopermissions' does not exist.
. 2009-03-24 11:34:01.149 Closing connection.
Command line usage:
"c:\Program Files\WinSCP\WinSCP.com" AAAA:BBB@XYZ.com /ini=z:\Admin\INI_files\WinSCP3.ini /script=s.txt /log=test.log
rmundkowsky
Re: URGENT - "put -nopreservetime" in script does not work, HELP
Found a work around which is to use a INI file with the following, but I think this is a bug that you should still address.
FileNameCase=0
PreserveReadOnly=0
PreserveTime=0
PreserveRights=0
IgnorePermErrors=1
Are you sure you are using the same version of WinSCP when run interactively and when running the script?
There may also be some syntax problem in the script. I've noticed that in the post the dash before nopreservetime is different to the one before nopermissions. And as WinSCP does report the error for nopermissions although it is only after nopreservetime, I guess it may be the actual problem.
rmundkowsky
incorrect character - my mistake, good catch
Wow,
Good catch. By some strange accident, I used a 0x96 rather than a 0x2D for a dash. Weird, I thought I was using a Ascii Text file for the script, but I guess it is an Unicode file.
