Don't have a 'public' folder
I just started using winSCP, so I am not sure if this is a totally pointless question - in which case, sorry!
Shouldn't I have a folder on the right handside of the window called 'public' which I should use to post on the actual website? I don't seem to have it.. what should I do?
Thanks,
F :oops:
Re: Don't have a 'public' folder
Maybe you are supposed to create the folder yourself. But you should better ask your webhosting provider.
