Hiding console window
analizer1
Hello, is there a way to hide the console window,
Im using wincp from c# program and system.diagnostics process
windowstyle is set to hidden, and i have standardinput and standard output redirected
thanks
daveL
Re: Hiding console window
Wither run winscp.com (if you need input/output redirection); Or omit /console parameter, when running winscp.exe (this does not support input/output redirection).
