Slow to open applications eg. excel
Russ1234
When WinSCP is transferring, I try to open an application such as Excel or Firefox etc but there is always a delay of 5 or 10 seconds before it opens.
Once the application is open, it's not a problem. I've got into the habit of leaving a copy Excel, Firefox etc open for use later.
Is there a fix for this ?
Thanks,
Russ
Re: Slow to open applications eg. excel
I haven't seen the problem before.
Do you see the problem with all applications (not only excel/firefox)?
When you open excel spreadsheet stored in local file by double clicking it, does the excel open quickly?
Russ1234
It's pretty much every application, eg Windows Explorer does it
No, it's not the case that excel opens quickly and the local .xls takes the time to be displayed. When excel opens after a while, it opens with the sheet loaded.
Regards
Russ
I'm sorry I'm confused. So it happens even when you open local file from Windows Explorer, does it?
