Synchronization
Alex_78
Synchronization
Have I correctly understand that when i realize synchronization with the script:
option batch on
open mark
option transfer
option exclude "*.idx; *.hdx; *.xdx; .htaccess; Backups; Cache; Logs"
synchronize remote D:\www\Sites\a1 /test/www/Sites/a1
close
WinSCP synchronize already available files, that is if i create a new file in a local directory it will not be written down in a remote folder?
And when i realize synchronization with GUI - all is transferred.
Re: Synchronization
No WinSCP synchronizes all files. Even new ones.
Alex_78
But in my version new files are not transferred in the removed folder. May be it is because of specific options or WinSCP caches status of directories?
Well, WinSCP synchronizes all file by default. It can actually be configured to synchronize existing files only. This can be configured in GUI only, but script uses the configuration. So please first check if this is the case.
