Change folder
Snozzi
Change folder
Hello! :|
I've got a problem when I want to change folder on remote system (ftp server) in WinSCP.
The structure is fore exampel like this:
Data
- afpds
- isis
- data
- ijpds
- isis
- log
- log
I can access the folder isis whitout problem and all subfolders under it EXCEPT isis which obviously has the same name as the parentfolder. If I change the name on the last subfolder from isis to isisa it's no problem to open the subfolder.
Tried the same thing on another ftp server and it's the same problem with WinSCP. With DOS comand ftp there are no problem access a subfolder with the same name as the parentfolder.
Any idea how to solf the problem whitout renaming the folders?
// Snozzi
Re: Change folder
The folder structure did't show so well in my previous message.
Data
-----afpds
----------fonts
-----isis
----------data
----------ijpds
----------isis
----------log
-----log
// Snozzi
Re: Change folder
ntdataavd
Sweden
Fond what was wrong...
Hello!
After I turned on the logging I found out what the problem was and it was the cache funtion had to be disable to be able to enter a childfolder with the same name as the parentfolder.
I've have attached the log file.
Link to log file: <invalid hyperlink removed by admin>
Re: Fond what was wrong...
Can you try to clear cache only, keeping it enabled? Just to see if the problem appears again.
ntdataavd
Sweden
Ceared cache
I have tried to enable the cache again and just clear it instead and that worked fine.
So now I uses the cache function and evrything seams to work just fine.
// Snozzi
