Automatically reconnect on lost connection
Max
WinSCP have option "Automatically reconnect session, if it breaks during transfer".
Can you add same option on "Lost connection"?
Oh, that I have missed for a long time.
I thought that "Automatically reconnect session, if it breaks during transfer" was the thing,
But I run into problem that winscp is expecting logon credentials in my case after a "lost connection" (Router restart or something (my isp isn't that stable)
So please, we need this!
Thanks in beforehand
//Blaj
WinSCP should restart the connection when it breaks during a transfer for whatever reason. So it does not for you, right? Can you post a log file showing that? Of course, supposing you are using the latest version...
Max
Winscp can't automatically reconect with messages with title "Lost connection":
Timeout detected.
Timeout detected.
Restarting at 0. Send STORE or RETRIEVE to initiate transfer
Timeout detected.
Timeout detected.
Connection failed.
Timeout detected.
Type set to A
Timeout detected.
Type set to I
Disconnected from server
Timeout detected.
Type set to A
Plus sometimes output message:
error listing directory '/dir_name'
Invalid access to memory
With 2 buttons: "Ok" and "Help"
