Change: Removed One file only editing mode in 8.1
magix
I'm using this feature in 8.0 and it's very sad that it was removed in future versions.
Why I need it:
1. I connect to the sunOs server via scp with "bash -c 'sudo su - username'";
2. winScp do not pick up the PATH settings in .profile of username, I have a workaround for that - setting the PATH manually thru terminal(Ctrl+T).
3. When I edit the file it opens in new session(since 8.1) and PATH is not set, that's why it's not possible to save the changes.
Could you, please, advice any workaround for this situation?
magix
Re: Change: Removed One file only editing mode in 8.1
Why I need it:
Or how to login(using "bash -c 'sudo su - username'") with PATH initialized?
I cannot test it now, but it may help if you move your settings from .profile to .bashrc. Or try to invoke bash a login shell (using --login switch I believe).
magix
I have tried .bashrc - it's not read on start-up. .bashrc was in the home/username directory.
The same with --login switch - nothing is read from .profile, .bash-profile. Switch was used here: "bash -c 'sudo su - username' --login".
I have tried also "bash -c 'sudo su - username' --rcfile ./.bashrc" - no luck. :(
In fact you should tweak the inner shell (the one run by su), not the outter one.
However according to su docs, the dash switch should cause su to execute the inner shell as login. But maybe your default shell (the one that su execute) is not a bash at all. Also I do not understand what is purpose of the 'bash -c' at all. You should be able to do sudo su - username only.
