Location profiles not saved
dshk
I am using 3.3, I tried both windows registry and ini file storage option. Actually it saved one profile, but it forgot the others. I explicitly saved the session after I added these locations (after it forgot them a few times). Another, maybe related thing, that I cleared the checkbox in the exit confirmation dialog box several times, but it still keeps me asking if it could shut down.
When I clean installed this version I copied a registry settings of a connection from another machine with a much older winscp client.
Re: Location profiles not saved
I cannot reproduce this bug, everything is stored correctly. Can you write me the most simple and the most detailed example of the steps you do, which would show that it does not work?
dshk
well, neither me, currently. I started to write a test-case, but of course it does remember the locations now.
