after timeout I get an abort window
cas
Hi guys,
I couldn't find a post on a similar topic, so I post this issue here:
I have an old linux machine, and now when I start up an SSH connection, it really starts up slowly. Of course I will go and figure why is that.
However winscp gets a "timeout" after 15 seconds, and gives me a popup window which tells about this issue, giving me only "abort" as an option to continue. All other windows are unavailable, and how often I click on "abort" or "x" in the upper right, it won't go away. I can only kill winscp via the task manager.
So I have two things:
1) I think this might be a bug (in version 4.1.8)
2) Is it possible to set the threshold for this timeout in the preferences somewhere? If not, this would be a faeture request :-)
Thanks for reading...
Caspar
Re: after timeout I get an abort window
Can you send me an email, so I can send you back a debug version of WinSCP to track the problem? You will find my address (if you log in) in my forum profile. Please include link back to this topic. Thanks.
Please read documentation.
However it probably won't help. The option just tells when the box should appread. The box goes away itself once the server finally replies.
