Path + filename limit
chadr
Version 4.1.8
Windows XP OS
I am copying files to a directory and get an error stating "can't create file....". The destination path + filename is quite long at 246 characters:
C:\Documents and Settings\Chad\My Documents\My Music CDs\A Tribe Called Quest - People's Instinctive Travels and the Paths of Rhythm (1990)\01 Push It Along, A Tribe Called Quest - People's Instinctive Travels And The Paths Of Rhythm (1990).WAV
If I shorten the name a bit by changing C:\Documents and Settings\Chad\My Documents\My Music CDs to a shorter path it is fine. I can then copy the files in Windows XP back to the original destination and it is ok.
Re: path + filename limit
I belive that this is limitation of Windows on some filesystems. Have you tried creating such file directly in Windows Explorer?
Pascal Boulerie
France
Re: path + filename limit (Windows)
Yes indeed : there is a limit around 255 characters for file names and file path names, including the backslash characters "\".
The only solution is to shorten the original path name.
(Another possibility would be to develop a rename pathname interface in WinSCP...)
E-mail
This topic is locked: you cannot edit posts or make replies
