"option confirm newer" possible?
UweKeim
Göppingen
When doing a batch transfer with the "put" command, I can set
To overwrite all destination files. But I want to only overwrite files that were modified locally.
What I am looking for now is a batch equivalent to pressing the key for "only newer" when being asked whether to overwrite.
Is this possible?
Uwe (https://www.magerquark.de)
Reply with quote E-mail
Made
Same question for me, is there a possibility for "overwrite if newer"
i want to do a little backup script. The archive can be several GiB. So it would be nice to have an option to skip files wich are not newer.
my script look like that:
open sftp://user:password@hostname.com
get files/backup.tgz C:\Backup\*
close
thx
crazykeynes
Re: "option confirm newer" possible?
You can use synchronize command.
But, there is a big issue in my environment.
We found that when only 1 winscp session running, it can not use the all of the bandwidth.
When I use 2 session I can see the the network bandwidth are fully used. Then the transformation efficiency is improved.
Synchronize can use only 1 session. Get can use multiple session. But when using GET, it can only "never overwrite" or "overwrite all".
Please help me to resolve this issue.
crazykeynes
There's no way to resolve your issue.
Really weird, in the GUI, "COPY newer only" is available, why just don't make it possible in scripting also?
anton_k
Hello Prikryl,
Is there any chance to have this option for the next release? It would be really helpful. Since with synchronize command you can't use file mask, e.g.
synchronize remote C:\DATA\*.dat
Thanks.
But you can do:
option include *.dat
anton_k
Unfortunately, I can't use -resume option with synchronize, which is crucial point for me.
Is there any other alternatives?
Not atm.
Mac
Hi Martin,
Thanks for writing a great application. Turns out I also need a synchronize -resume option, do you know when this is to be incorporated?
Thanks, Mac.
What should "synchronize -resume" do?
daniel55
Purpose of synchronize -resume
Hey prikryl,
We are looking at synchronizing a machine to a NAS, and synchronize does everything we need it to except resume file transfers. We need the external NAS to be exactly the same as the machine, so as files are added or removed, that needs to be reflected on the NAS. I need to be able to have an mirror copy every time we synchronize. I know that WinSCP does throttling, which allows us to transfer over long periods of time without chewing through bandwidth, but files are added and removed from the system constantly, so the script needs to be restarted frequently. If it is only partway through syncing a file and the script restarts, it has to start from the beginning of that file. "Put" is a good command, but we have to run synchronize after to make sure that everything is the same. Any ideas on an alternative to this issue?
Re: Purpose of synchronize -resume
What about splitting the synchronization into subtasks (per directory or set of directories) and let the script always finish its job?
