Assertion failed: Hard coded path?
JWoznica
I get an error window when try to run WinSCP 3.6.5. This window says:
Assertion failed: FSProtocol >= 0 && FSProtocol < FSPROTOCOL_COUNT, file D:\Martin\Projekty\WinSCP2\core\SessionData.cpp, line 935
It seems that there is a hardcoded path in the executable file. Do you know if that's been corrected already?
Re: Assertion failed: Hard coded path?
That's path to source code file. Probably that version was released in debug build by mistake.
Anyway, use the latest version.
