Is there any way to decide local and remote startup folders?
paer
is there any way to decide which directory I would like to have opened in local and remote on connect? In ws_ftp I have this sessionwide setting, but I can't find it in WinSCP3.
Best wishes,
Paer
Re: Is there any way to decide local and remote startup folders?
I'm sorry, I found it under environment.. But I'll post another question:
The values under Session (Host name, User name and Password) aren't saved when I save a session and try to reopen it. Though the values under Environment are saved.
Is there any way for me to save the session data (at least User name and Host name)?
Best wishes,
Paer
Did it ever worked? Or did it stopped working after you changed something?
Paer
It have never worked. I installed it earlier today and noticed it immediately.
Is it a bug, a non-implemented function, or just me?
I run WinSCP 3.3.0 (build 177) in Windows XP.
Thanks for help.
/Paer
I do not know yet, it never happened to me. :?
I cannot reproduce this bug, everything is stored correctly. Can you write me the exacts steps you do that lead to this problem?
