problem with subdirectory ...
daniello
I have any problems with change directory, that contains subdirectory named ... (under linux command mkdir ...)
then client froozen under w2k also xp professional
I have version 5.18 build 415
Daniel Mihalyi
Re: problem with subdirectory ...
Daniel Mihalyi
Ops, opf course version 4.18 build 415 :)
Daniello
What protocol are you using?
Protocol ssh2, version openssh-server version 4.3p2-9etch3 (Debian linux stable)
Example:
$ cd ~
$ mkdir work
$ chmod 700 work
$ cd work
$ mkdir ...
Then I try to connect from windows trough winscp to directory work and client frozen.
Daniel mihalyi
OK, I've meant if you use SFTP or SCP.
Daniello
Ah now I understand it, interesing question. For protocol SCP only, everything working properly and subdirectory ... is visible also. By using protocol SFTP or SFTP Allow SCP fallback, client going to be frozen.
Daniel Mihalyi
Daniel Mihalyi
On the server side, openssh-server supported SFTP subsystem, configuration file /etc/sshd/sshd_config contains the following line:
Subsystem sftp /usr/lib/openssh/sftp-server
Daniel Mihalyi
Can you provide me your email address, so I can send you a debug version of WinSCP to track the problem? If you do not want to post the address here, you can send me an email. You will find my address (if you log in) in my forum profile. Please include link to this topic. Thanks.
