Savannah
Leonidas
Savannah
Hi!
How to log in at savannah (savannah.nongnu.org) to upload files with WinSCP? It always complains about "Error skipping startup message (and something with bash)" and: Connection has been unexpectedly closed. Server sent command exit status 1.
The log:
. Looking up host "savannah.nongnu.org"
. Connecting to 199.232.41.4 port 22
. Server version: SSH-1.99-OpenSSH_3.4p1 Debian 1:3.4p1-1.woody.2.1
. We claim version: SSH-1.5-WinSCP-release-3.3.0.177
. Using SSH protocol version 1
. Received public keys
. Host key fingerprint is:
. 1024 66:f4:9a:7e:e3:a8:c5:16:d1:88:aa:ef:3e:06:75:30
. Encrypted session key
. AES not supported in SSH1, skipping
. Using Blowfish encryption
. Trying to enable encryption...
. Initialised Blowfish encryption
. Installing CRC compensation attack detector
. Successfully started encryption
. Sent username ERASED
. Pageant is running. Requesting keys.
. Pageant has 1 SSH1 keys
. Trying Pageant key #0
. This key matches configured key file
. Received RSA challenge
. Sending Pageant's response
. Remote dRSA authentication accepted.
. Pageant's response accepted
! Authenticated using RSA key "ERASED" from agent
. Authentication successful
. Started session
. Using SCP protocol.
. Skipping host startup message (if any).
> echo "WinSCP: this is end-of-file:0"
! You tried to execute: `/usr/local/bin/cvssh -c /bin/bash'.
! Sorry, you are only allowed to execute :
! - CVS_RSH=ssh cvs commands
! - rsync from /cvsroot or /upload.
! - rsync to /upload.
! - sftp to /upload.
! - scp to /upload.
. Server sent command exit status 0
* (ESshFatal) Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
* Connection has been unexpectedly closed. Server sent command exit status 0.
What can i do?
Re: Savannah
! - scp to /upload.
This should give you some clue.
Obviously you cannot use WinSCP is SCP mode with Savannah. See Requirements. Try to select SFTP instead on login dialog.
