Compatibility with WinSSHD
According to bitvise, WinSSHD should work with WinSCP: https://bitvise.com/ssh-server-usage-faq
However, I'm running into problems even though I'm running the SCP session under the bash shell...I think. :D
Here's some log info:
. Shell: e:\cygwin\usr\bin\bash.exe, EOL: 0
. Local directory: C:\, Remote directory: f:\FTP, Update: No
. Clear aliases: Yes, Unset nat.vars: Yes
. Doing startup conversation with host (shell).
. Skipping host startup message (if any).
> echo "WinSCP: this is end-of-file:0"
< WinSCP: this is end-of-file:0
. Detecting variable containing return code of last command.
. Trying "$status".
> echo "$status" ; echo "WinSCP: this is end-of-file:0"
. Trying "$?".
> echo "$?" ; echo "WinSCP: this is end-of-file:0"
< 0
. Return code variable "$?" selected.
. Looking up current user groups.
> groups ; echo "WinSCP: this is end-of-file:$?"
! /usr/bin/bash: line 4: groups: command not found
< WinSCP: this is end-of-file:127
I can log in fine during an ssh session, but for some reason my WinSCP sessions can't find the commands. For some reason maybe the path's are not compatible between WinSSHD and WinSCP? Any help would be greatly appreciated!
Re: Compatibility with WinSSHD
Have you tried to uncheck "Lookup user groups" option? (on Shell tab)
dcn19
Annapolis, MD
My original post only included a partial log. It wasn't just user group lookup that failed. Almost alll commands failed. I can supply the entire log if needed.
Please send me entire log
