ftp upload truncate sometime somefile
Cronos
I'm using the latest stable release, i'm trying this software from about 3-4 hours and it seem to be interesting.
I'm using the ftp protocol to transfer file from local to server with the commander mode.
Sometime ( not alwyas ) it truncate the file, just for example if the file have 50 line, at 30 line it truncate all, "</tabl" could be an example of the truncated line.
With the other software all goes ok, it does this problem with the php file, html, etc, all the text-plain file.
So, i tried to set binary file transfer, nothing changed.
If you need i can give you an account just to try by yourself ( the server is mine ).
It gave me the problem with varius file,tring to upload the file next-time the file stop at the same character.
If i try to delete the file, then, reupload, it stop at the same character.
The local-filesize are different from the server-filesize ( as shown in the winscp panel )
The filesize is about 3-4kb ( so nothing very big, or nothing very small )
Re: ftp upload truncate sometime somefile
OK, please create the test account for me. Thanks.
If you do not want to post account details here, you can send me an email. You will find my address (if you log in) in my forum profile. Please include link to this topic. Thanks.
ct24498
Any update on that issue?
I've exactly the same problem. I'm using WinSCP Version 4.1.8 (Build 415) on Windwos XP Professional SP2.
When transfering files from local to remote with FTP passive mode nearly every file is truncated even the small ones (1 to 4 kB) regardless of the transfer mode (binary or text).
Thx for your help.
N.b.: I'm using WinSCP now for 2 years or so and I am very satisfied with this excellent software. I used it with sftp und scp and it worked like a charme. Only the FTP mode makes problems now. Unfortunatly the provider of the remote system does not support scp/sftp.
Cronos_guest
I haven't done the test on the wired connection ( i had a LOT of work to do :( )
ct24498 have you a wireless connection or a wired connection?
if you have a wireless connection try to connect with the wired connection, else the problem isn't in the wireless
ct24498
Wireless testing
I'll do the test with a wired connection tomorrow, when I've access to the required environment (I'm not keen on doing cableing now).
Meanwhile I've upgraded WinSCP to Version 4.1.9 (Build 416). Situation remains the same.
Cheers,
ct24498
Re: Any update on that issue?
