Trnasferring files from one drive to another on remote serve
germain
I'm using winSCP 4.18 to connect to my newly purchased remote server with sftp-3. I'm a noob using a dedicated server. The server has 4 separate drives. These drives are located on the same level as the root folder. My provider has set things up so that I have separate ftp & http access to each drive.
I will need to be able to transfer files from one drive to another from time to time. When I attempt to move files, I get a general error 4 message. Not much help there. Is there a work around?
I have some limited shell experience and have transferred files from one remote server to another. But, I am stumped as to how I might set up the command to transfer form one drive to another on the same server.
Re: Trnasferring files from one drive to another on remote serve
Please read FAQ for the error.
If you have shell access, you may use "cp" command (providing it is unix-based server).
