leading and trailing spaces
I would like to suggest that leading and trailing spaces
are stripped out when ctrl-v is used to change path.
Re: leading and trailing spaces
For what do you need that?
Note that this would be possible with local paths only. As with remote paths, at least trailing spaces may by valid part of the path.
