"Resume" unsafe with SSH Server
songtm
Concerns WinSCP versions newer than 3.5.6, connecting to Tectia SSH Server.
The "resume" feature is unsafe and the uploaded file is corrupt.
If a file upload is interrupted twice, on the second "resume", the upload will finish instantly and apparently successfully - even when not all of the remaining bytes have been sent. The result is a corrupt file.
In contract, WinSCP 3.5.6 "resume" works perfectly with any number of interruptions.
Additional info follows,
Session protocol = SSH-2
SSH implementation = 5.3.9.3 SSH Tectia Server
Encryption algorithm = aes
Compression = No
File transfer protocol = SFTP-3
Additional information
The server supports these SFTP extensions:
newline@vandyke.com=0x0A
Re: "Resume" unsafe with SSH Server
What version of SFTP do you use with "newer versions"?
What kind of file it is? Text of binary?
Hi Martin,
I tested against these servers, SSH Tectia Server 5.3.9.3 and 6.06.19(latest release).
Winscp reported the file transfer protocol as SFTP-3.
Examples of newer versions that did not work - winscp405.exe, winscp415.exe, winscp418.exe. These would produce a corrupt file on the 2nd resume.
I tested using binary files, i.e. zip files which I can easily test for integrity afterwards.
Thiam
songtm
Martin,I have created the test account and sent the credentials to the email address listed in your profile. Thanks
Thanks. I have sent you an email with a request for more details.
ccamp
I have a client who is also experiencing this problem. Can you supply any updates on this issue?
It has been fixed already as you can see in the tracker.
