Convert special characters ±±±± to ------- in transfer
Jens Jespersen
Denmark
Hi
I have this filename ANL±±AP10±±±±±±M$LSK.±BR@ND±MED±1±PUMPE±±±±±±±±±±±TM003557.model and will like to copy to PC, no problem if PC are working in English, but if it is an Chinese PC, the special ± are converted to some special Chinese characters that can§t be used.
I will like to convert the ± to - when I do the transfer, is this possible?
Jens
Re: Convert special characters ±±±± to ------- in transfer
First you need to find how the conversion happens. It may happen implicitly in the OS or explicitly by WinSCP if it considers the remote filename to be UTF-8 encoded. What protocol are you using?
Then you can instruct WinSCP to URL-encode these characters, by manually editing following registry key:
REGEDIT4
[HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Configuration\Interface\CopyParam]
"LocalInvalidChars"="/%5C:%2A%3F\"<>|"
(note that some special characters are also URL-encoded in the configuration).
Note that the recent versions of WinSCP can transfer files with any characters in their names without any conversion.
