Minimize window failure
Victor
I start WinSCP from an icon direct access in desktop, in this way:
C:\WinSCP3\WinSCP.exe "My Website" /synchronize C:\Backup /backup
then a window shows the transference process with two buttons: "Cancel" and "Minimize".
please, see the attached pic
The "Minimize" button doesn't work but it opens a new empty window.
I'm using XP Sp2, WinSCP 4.1.8.
thanks,
Re: Minimize window failure
I works for me.
So can you give me more details?
Is there anything unusual about for computer? E.g. multiple monitors? Virtual desktops?
What was the state of the main window before you pressed Minimize button?
Victor
just to report this malfuncion still is alive in recent versions.
This is the scenary:
1- create a connection shortcut in the Desktop to execute a scheduled connection:
C:\WinSCP3\WinSCP.exe "My Connection" /synchronize C:\Backup /backup/serverbackup
2- create a task in the TaskManager:
3- When the connection window appears in the deskttop, try to minimize the Window
- tested with: WINSCP 4.2.1 build 428
- XP Service Pack 2
- NVIDIA Gefore with Dual monitor
thx!
