Editing _remote_ files with external editor
Taci
I use WinSCP to edit source files on a webserver, and the only think i miss from this great tool, is editing remote files with my favourite programmer's editor (jEdit actually)
I download the file, edit it locally, then I copy it back to the server. It's too many steps! :cry:
Total Commander (Which I can't use becouse it lacks SFTP support... :( ) copies the remote file to a local temporary folder, calls externel aditor with THAT filename, and when I close the editor, it transfers the file back. That's nice, it saves me some steps :wink:
Thanks for WinSCP, I like 'Synchronised browsing' feature best, it _also_ saves time/clicks! 8)
Re: Editing _remote_ files with external editor
WinSCP has this functionality too, since version 3.0! You may specify your preferred editor in Preferences.
st
Wow. I've used both jEdit and winscp for quite some time but never knew about this configuration. Thanks for the excellent hint.
