timeout waiting for external console to complete the command
Running winscp.com with a script file that FTP puts a few hundred files works fine when I type it in a cmd.exe window, but when I try to use it as a process object in my .Net 3.5 program, I get a pop-up dialog with the above message after about thirty seconds. The process continues to run, but no more files get transferred.
Is there a way to get around this timeout?
I'm running WinSCP version 4.1.7 on windows XP, visual studio 2008.
Here's my script file:
The script file works fine from a command prompt window.
My program code:
The process continues to run: my log object (above) reports "FTP running..." indefinitely.
thanks
open creynolds@winsrvops option confirm off option batch on cd attachment lcd W:\ibm\WebSphere\AppServer\profiles\ecstg\installedApps\WC_ecstg_cell\WC_ecstg.ear\Stores.war\APHConsumerDirect lcd attachment put *.* lcd .. lcd upload cd .. cd upload put *.* lcd .. lcd images\catalog cd .. cd images\catalog put *.* bye
My program code:
... Sub FTPfiles(ByVal localdir As String) ' Purpose: FTP the image files, etc from ecstage to web server ' Created: conrad dec 2008 ' Modified: Const THISSUB As String = "FTPfiles" Dim proc As Process Try BuildScriptFile() StartProc(proc, My.Settings.FTPFilePath & "\winscp.com", _ "/script=""" & My.Settings.FTPFilePath & "\WSCPromotionBatch.txt""", 10) Do If Not proc.HasExited Then proc.Refresh() If proc.Responding Then log.Comment("FTP running...", THISSUB) Else log.Comment("FTP not responding.", THISSUB) End If End If Loop While Not proc.WaitForExit(10 * 1000) log.Comment("FTP process exit code:" & proc.ExitCode, THISSUB) proc.Close() Catch ex As Exception Throw New Exception("Error in " & THISSUB, ex) Finally proc = Nothing End Try End Sub Sub StartProc(ByRef proc As Process, ByVal cmd As String, ByVal parms As String, ByVal waitseconds As Integer) ' Purpose: Start up the specified command as a process ' Returns: A Process variable for your process. ' Created: conrad dec 2008 ' Modified: Const THISSUB As String = "StartProc" Dim procStartInfo As ProcessStartInfo Try proc = New Process() procStartInfo = New ProcessStartInfo(cmd, parms) procStartInfo.UseShellExecute = False procStartInfo.RedirectStandardError = True procStartInfo.RedirectStandardOutput = True proc.StartInfo = procStartInfo proc.Start() proc.WaitForExit(waitseconds * 1000) Catch ex As Exception Throw New Exception("Error in " & THISSUB, ex) Finally procStartInfo = Nothing End Try End Sub
thanks
