Password box in 3.3
Bob Isaac
Password box in 3.3
For some reason, a dialogue box comes up and asks for a password when starting v3.3, even though the password is saved. Even if I put nothing in the box and click OK it will still connect. Any ideas?
Bob
mattgick
do you happen to have an @ in you password? same problem here ;) using FreeBSD...
for some reason I don't have this problem in linux, maybe because that one is running the latest version of openssh... might by BSD related though...
prikryl: I posted a topic on this a while ago... just to let you know, the problem seems to not exist in linux with openssh 3.7.1_p2
and indeed bob, if you click OK without reentering the password, authentication still succeeds... weird ;)
I've had a same problem few days with OpenSSH server on Sourceforge (and only with this server). I was not able to find a cause. Several days ago, the problem disapeared and it never happened since. I was not able to find out, if there were any upgrades at the time.
Chris from NJ (USA)
A fix for the unneeded password prompt?
I'm new with using WinSCP, but found myself reading the forums because I too have the same problem.
Under SSH Authentication, if I uncheck 'Attept "keyboard-interactive" authentication (SSH2)' -- I think it fixes it.
Try it and see.
Chris
Re: A fix for the unneeded password prompt?
What is your server?
Mike
I admin Chris' server, to be specific the server is OpenSSH_3.7.1 on Linux.
ssh on linux
Thanks for the info.
