Relative putty.exe path
linuxamp
I read the forum posts about relative RND and keyfile paths as well as the "portable" section on the manual page but the path to putty.exe must still be absolute.
./putty.exe not found.
linuxamp wrote:
Sorry, I typed it wrong here in the forum. It was .\putty.exe which didn't work.
Will try that. But first, are you aware that the path is relative to WinSCP startup directory, not to path, where winscp.exe is located?
